Any particular colours in mind?
Black and pearl dark gray
Should be easy enough to work with
Give me an hour or so and I’ll see what I can make, this’ll likely be helpful for my own bat building projects too
Ok thank you
after some experimenting I have come to the conclusion that it is insanely difficult to make anything substantial using just CCBS
I have plenty of other designs that use a mix of systems if that’d be useful?
Uhhh…how big?
Didn’t even have to read the username to know who this was… I can’t tell if I look forward to the result or if I dread it with every fiber of my being.
Think I’ve figured it out, give me a little bit and I’ll make some breakdowns
Don’t have her built anymore but from what I can remember it’s directly taken from here
Only difference being that no pieces need to be cut since a 3L axle with stop is a piece that actually exists now
Thanks! Do you have the thigh figured out yet?
That’s a clever design. Now that you have it built, how well does it hold its position? Like, I see that CCBS bone piece is connected with the socket, so does it wiggle around or can it stay sturdy?
It’s pretty sturdy, the ball in the middle of the CCBS limb is pressed tightly against the visorak feet creating lots of friction, so even though there’s technically a joint there it’s all fairly solid
Looks pretty simple to me, you can see the entire construction right there. It’s just a bunch of sockets strung together
Yeah, looks pretty simple. Just that technique with sockets and 2 axles. I gotta try that, though, it looks nifty.
I need some help with an arm/hand idea. the whole idea is its based off general grevious arms but id need the wrists to move around like a normal wrist but also combines to form a larger hand. does anyone here have any ideas on how to do this?
