The impact of the tail would most likely send him flying while also causing some damage to his chest as he let himself get hurt by it.
While the recoil does knock him back, Scaleraker’s thick scales would prevent damage. Scaleraker would curl into a ball, and he would roll at high speed at Voltex.
Voltex rose his mace sword and slammed it down at Scaleraker as he curled into a ball and rolled towards him,.
This would do less damage than the stinger, as the scales on the outside were even thicker, and the strike would do nothing to stop his momentum.
But Voltex using his incredible strength would as he pushes the mace sword into him, trying to stop him as he placed his foot very firm. Putting his knees and back into it.
That may stop Scaleraker, but it would probably also topple Voltex from the sheer weight and speed.
OOC: okay, think about the physics here. You have a heavy, spheroid, traveling at high speed. Simply slamming the mace down would do nothing. If you put your foot down to stop him, he may stop, but all that kinatic energy is now transfered to Voltex, which should, at the least, knock him over.
“Well… It is a fact that we were the good guys!”
Demolishor, a Decepticons twice bigger than Voltex in any way, saw the opportunity and prepared to Hulk-smash Voltex while he was fighting Scaleraker.
@MichaelBT-7474
Mirage approached the group of Seacons. To the other Seacons’ protests, Halfshell walked forward and closer to the enemy. By far he was the most hurt out of them all.
“You want to die first?” Mirage asked.
“You… Have no Decepticon honor!” Halfshell said, struggling to talk.
“Well, I never was a Decepticon. I was and Autobot, then a Maximal, then a Vehicon, and then… Whatever I am now, but I was never a Decepticon.”
As Birdbrain continued to mumble, Rippersnapper turned confused to Forager.
“What is he saying?”
The fact that Ravage suddenly started growling was also giving Rippersnapper a feeling of unease.
@Chromeharpoon
While Scaleraker was stopped, the sheer weight and speed would merely push back Voltex a step because of his strength upgrade, he received from Starscream.
Voltex turned his mace sword upside down, holding the handle with both of his hands as he pointed the sharp point at Scaleraker and thrusted the blade down, in an attempt to impale Scaleraker.
Voltex’s tailed jumped out of his back and moved in an unorthodox way as it swirled around, the pointing sharp point of the blade came towards Demolishor and from behind attempted to stab him.
The sword may do some damage to Demolishor, but this would do nothing about the incredible speed with which his fists were approaching Voltex, as two massive blocks of concrete.
The blade would simply glance off, skittering down his overlapping scales. Scalerakee transformed quickly and slashed with his claws at Voltex’s abdomen.
On the other side of the whole, Mirage and Halfshell were dueling with their swords. Even with his shield, Halfshell was in a great disadvantage. He would barely rise his sword, and was getting hit after hit after hit from Halfshell.
Starscream, located between Voltex and Mirage, studies the two fighting groups, contemplating deeply if it was really worth it to upgrade so many beings instead of making his own body.
Suddenly her rises his glance.
“Something not good is about to happen…” the ghost says to himself.
Forager shifts his gaze to Ravage, holding up his pistols.
“Re-what?” Rippersnapper tried to guess from Birdbrain’s mumbling. “Revive? Regenerate? Recreate?”
“Re-re-re-ne-gades-es…”
“Renegades?!” Rippersnapper said in fear louder than he would have wanted.
However, it was already too late for Rippersnapper to keep whispering. From the shadows five Decepticons showed up, each having their weapons prepared and pointed at the five. Forager might recognise them as
Wingspan,
Pounce,
Cindersaur,
Slugslinger,
and Long Haul.
Forager keeps his own pistols pointed at the five.
“Whoa, whoa, whoa there, guys!” he calls to them. “We’re all on the same side here!”
Pounce and Wingspan started laughing.
“Get 'em, boys!” Slugslinger said as the others started shooting.
“Whoa!” Forager exclaims as he ducks down, transforms, and scurries toward cover.
The two clone brothers would give chase.
Rippersnapper takes a lot of hits and falls to the floor, badly damaged. Birdbrain and Icepick try to hide in their cryogenic tubes. Ravage direct his two machine guns to the three that remained in front of him, shutting at them fiercely and forcing them to take cover.
@Chromeharpoon
Forager transforms to robot mode, keeping low to the ground as his legs become wheels. Deploying an energon pistol, he shoots twice at Pounce as he equips his tail’s cutting laser.
Pounce dodges the first hit, but the second hits him in his shoulder. It seemed like both of the twins felt that, as both cry in pain, covering the wounded shoulder.
They then turn into their eagle and jaguar modes and continue chasing Forager.
