I don’t think I’ve shared this here before, even though it’s a few years old at this point:
This is a combiner between Jaller, Hewkii, and Nuparu Mahri. It started off as a kaita, but I’m not really sure if it’s big enough to justify that. I suppose this could just be some unrelated Toa of Fire, maybe?
This whole thing was done for the single purpose of using the Volitak with two big sweeping tubes coming out of both sides, which I think looks cool. As a bonus cool parts usage, the tubes plug into the Garai, which is used on the back as armour:
Obviously the Garai is a placeholder and is colliding pretty bad, but this was originally built with physical parts, and I can confirm that it works fine with the actual Garai.
While the limbs are extremely basic, I’m happy with how the torso came together. It’s taller than a standard Inika torso, and uses some non-torso pieces for armour:
The sword is just a tricked-out version of Jaller’s Power Sword, with some jewels in the base of the blade and small fangs along the flat:
Where did you get those masks? They aren’t in the Biopack!
I like it a lot ![]()
Any plans to do a Kongu-Hahli-Matoro combo?
The Volitak’s in Toa Mahri File from the Digital Constraction Collection
As @Atobe_Brick said, I got them from the DCC file for the Toa Mahri. It has the Volitak, Faxon, Tryna, and the dual-coloured Arthron. There’s also a variant of the Zatth, and a scaled-up version of the minifigure Garai. I used Khingk’s Garai variant in the above images, though.
I wasn’t planning to, but I simply hadn’t thought to. Maybe I will at some point. That colour scheme could work as a Toa of Plantlife.
This was originally made with the physical sets, and I don’t have Kongu Mahri, nor did I want to mess with Hahli Mahri’s joints, so it just never came together when this one did.
That point is now:
I tried to make the colour scheme as cohesive as possible, but I was forced to use Matoro’s torso. I’d say it’s still close enough to be a Toa of Plantlife colour scheme, though.
This combiner takes a lot of cues from the first. The base torso construction is identical, and there are some similar armour patterns as well, such as the shoulder pauldron/light source combo, silver mask, and the foot-based torso armour. This one also uses a shield.
On the back, there’s a bunch of tube connections, as well as spare Cordak rockets:
The two combiners look pretty good together:
wow these two look really cool
Yeah for combiner models they look great!
Smol Optimus prime made out of the 76203 Iron man and 76202 Wolverine mechs
He can transform, but this doesn’t really look all that much like a truck
I decided to make a combo model of of the Bone demon MK mech and the new combi mech.
The back is mostly unchanged incase I give the dragon jet the same treatment.
wonderful
Looks cool
nice mech
These could work.
Ended up getting 3 of the z blob robot set and combined a couple into this nightmare z blob
The only part in the build not from the base set is the trans green head in the dome.
I am practicing my Bionicle building skill by mixing all six Vahki into one using Herculeskabuterimon as the inspiration. I haven’t decided on the name for this MOC yet.
Nice! That’s a good combiner there!
I appreciate that you mixed up the head and eye colours, rather than just reusing the exact Vahki heads.
Also, are those pins supposed to be sticking out of the top of the white/blue “central head”, or is that an error?
I just noticed it so I think that’s an error when I was building it.
That combiner is quite the, uh… combiner. Reminds me of the Ninjago Ultra Dragon from the second year.
