I’ll check later and, if I have to, I will merge them.
The mods seem to have a way to merge topics more quickly and efficiently, so they’ll probably take care of it.
A few things:
1: You can not submit your Hagah individually. Make all you want to, then submit.
2: Has to be one (1) topic, not several.
We’re not accepting your entries yet until you have determined yourself done with which you want to enter. Once you are, repost in the entry topic with this topic after you’ve fixed it. That means modifying the title and adding all of your Toa to the main post.
Thank you.
Take my words as you will, I was only trying to settle a situation.
If a stove can get hotter than summer temperatures in lower latitude states/countries, does that mean that they do not have hot summers? While I fully understand that builds can be much more complex, like Artakha for reference, I chose to use the term more complex to take note that it is more filled out than a regular set would have it. To that end, I never stated that this model was complex.
- I never said that no good revamps existed, or that there weren’t any from my point of view. It is only in reaction to your statement of there being no set that looks better than its revamps that is subjective to opinion. There are wonderful, outstandingly detailed yet suitable builds, and there are oddly shaped, unnecessarily and disproportionately bulked out builds. Beyond that, I do agree that some revamps can look better, when done right.
- The “one sided eye friendly” rule typically did not occur with Bionicle. Rather, it is more meant for buildable play sets to provide (or at least attempt to) an appropriate balance of play and display. While some Bionicle sets do look a little off from certain angles, they are more often than not designed with an enclosed form to be seen from many angles and still be recognizable as what they represented. If you are implying that the back side of the Metru torsos look awful in this way, even if there is a community to back that idea, it is still a subjective opinion.
We all can give in. Sometimes our words just aren’t what we mean. If my words came out as such attacks, then I, too, apologize for using any misleading language.
I never said that you were not making any logical points. I was only attempting to settle the situation before behavior issues became a disqualifying factor for your entry. Your entry does follow the rules, and as such, has every right to be entered officially into the contest. I never argued against that fact.
That’s all I was trying to prevent. Again, I apologize if it did not seem that way.
Ok, I’ll create new topic with all toa hagah after I finish them. That will be ok?
Just modify this one.
I think you forgot to give your consent on changing the design for the final art work (mask, metallic color, spear).
Is it ok now?
Love Bomonga, he looks super powerful
Thank you for entering.
Everything is fine, except that Gaaki’s shield is primarily blue and not primarily metallic. It will need to either be made more metallic like her armor or we can’t accept it.
Please fix this before the entry period ends. Thank you.
Done! Idk why, but it did not marked you in previous comment, so I’ve added a new one.
